vcProductMatcher
vcProductMatcher monitors product needs and feeds and matches them with each other. A vcProductNeedFeedMatch instance is created for each matched pair. A match can be made if the process group ID of the need and feed matches, the product type is accepted by the need (defined in product filter), and a valid transport solution exists between the transport nodes.
Referenced by: vcProcessController.ProductMatcher
| PendingFeeds | vcList[vcProductFeed] | R | Gets a list of all pending feeds. |
| PendingNeeds | vcList[vcProductNeed] | R | Gets a list of all pending needs. |
| addFeed | None | vcProductFeed feed | Adds the product feed to the product matcher to be matched with a need.See moreParameters: feed (vcProductFeed): The product feed to be added to the matcher. Exceptions: ValueError: When product feed has already been added to the product matcher. ValueError: When product feed has been matched, it cannot be re-used before the match is disposed. |
| addNeed | None | vcProductNeed need | Adds the product need to the product matcher to be matched with a feed.See moreParameters: need (vcProductNeed): The product need to be added to the matcher. Exceptions: ValueError: When product need has already been added to the product matcher. ValueError: When product need has been matched, it cannot be re-used before the match is disposed. |
| OnPendingFeedAdded | vcProductFeed feed | Triggered when a new feed has been added to the product matcher. Parameters: feed (vcProductFeed): The added feed. |
| OnPendingNeedAdded | vcProductNeed need | Triggered when a new need has been added to the product matcher. Parameters: need (vcProductNeed): The added need. |
Example: Access Process Modeling Main Objects
""" Access main objects for process modeling in vcCore.""" import vcCore as vc world = vc.getWorld() pc = world.ProcessController assembly_pattern_manager = pc.AssemblyPatternManager flow_group_manager = pc.FlowGroupManager flow_table = pc.FlowTable process_manager = pc.ProcessManager product_matcher = pc.ProductMatcher product_type_manager = pc.ProductTypeManager transport_system = pc.TransportSystem
